Question about Export to STL
12090.2 In reply to 12090.1
Hi Frederick,
> So how does the export on multiple objects into one STL look in code?
If you want it to do the same as the File > Export command you would turn on selection on all the parts that you want in the same file and then call moi.geometryDatabase.fileExport( 'filename' );
If you are stuck please post the script.
