Hi everyone,
By 'corner point,' I mean a point that behaves the same way as the start and end points of a curve.
Meaning that it is actually "on the curve" and when i move it, the transition on each side is not smooth anymore.
when having a look at the object properties : i do not see a way to identify a curve with additional corner points.
the properties indicates 8 edit points but, there is actually 5 control points and 3 corners points (start point, end point and the one i added).
when i want to get rid of extra corner point, i usually run the fillet command.
unluckily, the fillet commande script is not the easiest for me to understand.
Hadri1
