extract information regarding an object (Details)
12081.4
Hi everyone
1- As for corner points, it kind of depends on your exact definition of what a corner point is.
I’d love to know the definition (without giving up a kidney for it, no way!).
But it’s mentioned in the MoI3D help: For curves, you can create a point that will form a sharp corner when moved by checking the “Make corner point” option or holding down Ctrl while clicking.
2- Are you looking for the points on a curve where it forms a sharp angle?
Well, I’d really like to have those—or rather, see them (a point of a different color or shape, or a small square the same size as a point)
3- Is there another type of corner point where the curve is currently smooth at that point, but where, if it were moved, an acute angle would then be formed at that point?
‘’‘My answer is YES’‘’ I’ll clarify – I didn’t express myself clearly. There may be a corner point on a curve that we cannot see because the curve appears smooth.
At present, corner points (I’m referring to the points you see when you click on ‘Show pts’) are indistinguishable from standard points. But the ‘Properties’ panel provides the relevant information. Furthermore, with practice and experience, you learn to spot them (though it’s not always easy!).
4- Real acute angles will cause the curve to be divided into distinct segments.
Imaginary acute angles will also cause the curve to be divided into distinct segments, but we won’t be able to identify them!
X- Well, friends, I’m attaching a few screenshots and a file to fuel your thinking and the discussion. Feel free to adjust the visibility of the various elements and enable or disable the points (there are corner points among them!)
In addition, the Properties window displays different information depending on what you select; this can be helpful when creating or modifying the elements you design.
Warning! DeepL translates my French into English but plays tricks on me and doesn’t really convey what I’m thinking
EDITED: 24 Aug 7:54 by ZOOEN
Size: 308.2 KB, Downloaded: 20 times, Dimensions: 2560x1438px
Size: 301.2 KB, Downloaded: 12 times, Dimensions: 2560x1438px
Size: 336.5 KB, Downloaded: 15 times, Dimensions: 2560x1438px
Size: 265.1 KB, Downloaded: 8 times, Dimensions: 2560x1438px
Size: 408.7 KB, Downloaded: 13 times, Dimensions: 2560x1438px
