extract information regarding an object (Details)
12081.3 In reply to 12081.1
Hi hadri1,
> i would like to start with a curve element and print information such as
> the number of points and number of corner points.
You can get the number of edit points for a curve by the .numEditPoints property.
For corner points, it kind of depends on what your exact definition of what a corner point is.
Do you want the spots on a curve where the curve has a sharp corner in it? Or there is a kind of related type of corner point where curve is currently smooth at that spot but if you were to move it you will then get a sharp corner there.
Actual sharp corners will cause a curve to be divided into separate segments.
You can get the number of segments in a curve by calling:
var segment_list = crv.getSubObjects();
var num_segments = segment_list.length;
> for surface i could would like to have information on U and V iso curves.
In v5 a face has face.numControlPointsU and face.numControlPointsV properties for the number of columns and rows in the surface's control point grid.
