extract information regarding an object (Details)
12081.10 In reply to 12081.9
Hi Zooen,
> How does this script (code) work?
> I've tested it but I can't see any results.
That script contains a function which given a curve returns the number of corner points in the curve.
It doesn't do anything if you try to run it all by itself, it is a building block that can be used in a larger script.
