Hi Mark, welcome to MoI!
I like the front page of your web site - it's got a nice panoramic open feel to it.
For your image alignment, probably your best bet would be to first use Draw curve / Rect to place a rectangle, entering in your precise width and height in the upper-right corner options. Then when you are adding a new image plane with View / Image, you should be able to snap on to that rectangle to get your image to your desired size in units.
It would be better if you could just specify a width and height in units directly inside of the image placer though, I have made a note to add this for V2.
Thanks, and let me know if the Rectangle trick does not do what you need.
