Images in the Object Library
12073.7 In reply to 12073.1
Hey Frederick,
Amateur answer for you here....
The "size" of your object seems to matter with how Max coded the image generation. So if a single object, small enough is the target, then you get a great image.
If its "larger"-"Offset"-"Multiple objects" in viewport, then it gets truncated like you show...
This part of the configuration code seems to control a "Zoom Factor" which controls how much can fit in a "centered view"
vp.zoom(1.2);
Look in the ObjLibrary.menu.htm file
So my amateur answer is you can set a larger value to "zoom out" and have it fit your larger object or scene
An "expert answer" could take a better look at the code and see if it could be a more "dynamic size" for all related scenarios...
Anyway.... Thats all i got.
Maybe someone else will jump on it....
