Hi Martin,
It may well be.
I don't remember installing it.
Let me do a bit of research...
OK I got it from here:
https://moi3d.com/wiki/MaxScriptArchive
It's the item at the type: Custom UI
As you can see Max S has been a source of many good things.
The Object Library that is part of it came with a few demo items but you can add your own - it's quite simple.
The great thing is when you pick a part to use, it appears ready to adjust it's orientation to whatever surface you need, at whatever point you need it.
Frederick
