New Section command
12071.42 In reply to 12071.41
Hi PIlou,
> But it's only one color for all the surfaces and not each separately!
You can do it separately if you run the Section command 3 separate times and only generate one section each time.
You can also set up a keyboard shortcut that will enable just one specific plane at a time, like this:
Section UseXY=true UseXZ=false UseYZ=false
