Hi Frederick,
> Perhaps a code fix is in order so the case of the names doesn't matter so the
> scripts in all cases work as intended.
That's something that would need to be fixed in the script.
Where your script is calling if ( a == b ) that's going to be a case sensitive comparison, that's how the Javascript == operator works with strings.
If you want it to be case insensitive you could do something like if ( a.toLowerCase() == b.toLowerCase() ) instead.
