Spiral following an outline inside a closed curve
12030.1
I am looking for an efficient way to create a spiral that follows the inner outline of a closed curve with a defined distance between the lines.
For example, starting from the upper-left corner of a rectangle, the spiral would follow the shape’s interior outline, continuing inward turn by turn at a specific offset distance.
Could you suggest a method or tool to achieve this?
Joerg
