Command Palette Search Commands & Scripts Fast ⚡
12014.17 In reply to 12014.5
live update mode... Llamas @ Work.....
Following a key moment of inspiration, the Command Palette has been updated.
The big addition is Key Groups, where the multi function llama button returns to assist you
with inspirational shortcut duties.
Key Groups are user-defined tool sets for creating custom command panels.
They can contain commands, launch scripts, support workflow-specific tool sets, and be triggered
directly by MoI shortcut keys.
The new Group button creates, edits, and accesses Key Groups using a toggle mode.
Yo Llama Group button
Left-click: create/edit Key Groups (Function 1)
Right-click: switch between Command Palette and Key Groups (Function 2)
To create or edit a Key Group simply left-click the Group button, enter its name,
build or modify the tool set, then press <Enter>.
Using an existing name edits that Key Group; a new name creates one.
Names can be a letter, word, phrase, or abbreviation.
Example Keygroup names, might be:
>My Top Scripts
>Smirnov Top 5
>Drawing Tools
> "F" for file menu and save tools
>Dimension Kit
4 personality llama, on button
Preview:
Command line / shortcut syntax:
commandpalette
Opens the standard Command Palette.
commandpalette keys
Opens directly in Key Groups mode.
Not often used as tool remembers last toggle state now
commandpalette <yourkeygroupname> (no spaces)
example keygroup: My Top Scripts
MoI3D MyTopScripts shortcut
Key zero opens that specific Key Group page called "My Top Scripts"
MoI3D MyTopScripts
OTHER:
Key Groups Presets are stored as JSON in:
`%AppData%\Moi\CommandPalette.KeyGroups.txt`
Name them carefully or edit your text file.
**Advanced**
• **KeyGroup Export**
Shift-left-click Group to export the pinned Key Group as a small shareable text file. (Function 3)
These are saved like this:
CommandPalette.KeyGroup.mytopscripts.20260502-1749.txt
in location: `%AppData%\Moi\
• **KeyGroup Import Ready** (Function 4)
Shift-right-click Group checks for a future `CommandPaletteImport` / `CommandPaletteTools` command.
If not installed yet, it shows the Llamafield Keys Import future-release message.
**Summary v1.45**
• New Key Groups.
• Toggle between Command Palette and Key Groups.
• Create user-defined Key Groups.
• Build custom command panels for frequently used tools and workflows.
• Pin your favourite Key Group for quick access.
• Remembers the last active mode.
• Previous/Next navigation between Key Group Panels using mouse buttons or <> keyboard shortcuts.
• Direct launch of Key Groups from MoI shortcuts.
• Export pinned Key Groups as shareable JSON text files.
• NEW Base64 'Lightning' Icon for Max's Custom UI. left click for Command Palette, right click Keygroups.
EDITED: 6 Jun 15:21 by LIGHTWAVE
