Moi3d and 3d scanning
12004.23 In reply to 12004.14
Hi pafurijaz,
> So that’s why I suggested this approach, considering that Moi3D doesn’t have a way to import
> STL files, except for some JavaScript scripts, and I figured that having a STEP file, even
> if polygonal, could let you do the reconstruction right inside Moi3D's tools.
This is true, but the reconstruction process has a very high learning curve and is better done with tools that are specifically focused on that type of task which MOI is not.
The OP asked:
quote:
scannes items can be exported as stl and obj...so import the obj ...I ll be fine?
The simple answer is "nope, you cannot just open up scan data into MOI and proceed like it was an object you modeled."
