Hi Yanus3D,
> 1. I would like to have one layer after exporting.
> MoI produce like tens of them (its coming down from Rhino system probably)
> Maybe at first you can create one Layer as option in MoI LWO exporter (I suggest make
> it fix, because these layers are useless)
Do you mean having just one surface in the LWO file so everything will be the same render color?
> 2. Also another option:
> Is annoying that MoI pass down smoothing surface threshold at 20% for all surfaces (this
> probably comes somehow as default surface option from Rhino...)
> This is of course again next useless parameter and all surfaces should have no smooth
> threshold at all.
I can put in an option in moi.ini to not write the smoothing angle chunk.
