Hi!
Finally I could use beta (MoI 5.0 beta Apr-27-2026) and I see that UVMaps and Vertexes I can remove during exporting (ini config)!
Thanks! This really helps.
I remind about Pivot Point Issue (you know already where is problem) to add it in the next update.
Here screenshots how beautiful export module of MoI does for Lightwave :)
One image shows Pivot Issue. I can deal with this manually by resetting to zero coordinates - issue with wrong scales Meters to millimeters in MoI Exporter. Object has original 230 meters shift position and must still there. I cannot switch into meters Units in Moi because I get errors in views so this solution not helping.
