Multi purpose scene browser / workflow script for toggling quickly from Inside Scene Browser View
to adjacent scene browser view. We really like mode 5 or: "Browser 4".
How it works:
The browser toggle script is designed to keep your workspace compact and use the inside scene browser
view (as default) until you need to see more detail or bigger/longer/expanded lists (objects, styles etc).
To make this work. rename script
browser.txt to browser.js
and put the script in the usual 'commands' script folder.
Then set up your default browser view as: inside
moi 3d options > general > scene browser position > inside
Configure a shortcut key or use command line box in moi.
Command Line or Shortcut Key Commands below, there is 5 options
or commands:
Browser 0
Browser 1
Browser 2
Browser 3
Browser 4
1.
Browser 0
Toggles from browser inside to browser adjacent.
All tools: objects, types, styles remain closed.
2.
Browser 1
Toggles from browser inside to browser adjacent and opens "Objects"
3.
Browser 2
Toggles from browser inside to browser adjacent and opens "Types"
4.
Browser 3
Toggles from browser inside to browser adjacent and opens "Styles"
5.
Browser 4
Toggles from browser inside to browser adjacent view and opens "whatever you had opened inside view"
before you activated the toggle, so if you had styles open when activating this command you will see
the styles tab open in the adjacent view.
Pressing the toggle or shortcut key toggles back to default state (inside).
So you can now get from a partial inside view:
To a full adjacent view with a single keyboard shortcut...
thanks to Michael for this functionality.
