Anime 2D from a SVG Moi File
11992.4 In reply to 11992.3
No the SVG format is the only one i can use with Gemini for this sort of thing! :)
But i can use the Drag & Drop (but you have not the image PNG in the same time - only the objects) or the copy from the clipboard!
You have not exactely same menu of SVG export when you use your SVG shortcut !
Here the conceptual manual ;)
EDITED: 11 May by PILOU
