Anime 2D from a SVG Moi File
https://moiscript.weebly.com/anime-svg.html Little English PDF Manual inside!
Made with Gemini free version ! Mix of Html of the day , SVG, JavaScript , Jason CSS3
So i made my personnal one! :) You can open it from any devices by any browsers!
As I need it for a specific project here the prog that you can use without restriction! :)
So you can modify it and enhance it without any problèm!
You draw something in Moi, export as SVG format !
If you want name object in it : you Name it inside the Moi Color Style section!
It's just animation of lines drawing! (no surfaces but you can put any image under it)
Here a 3D Projection at the Moi SVG export! You can enable "Generate Outlines"
EDITED: 10 May by PILOU
