Custom fillet with G2 curvature
11984.2 In reply to 11984.1
Hi geekmidget, select the inner cone piece and then run the merge command on it (press tab key to put focus in XYZ bottom input that works like a mini command line, then type merge and then <enter>).
Then there will be just one edge on each object, select those and then you can do Blend.
When there are more than 2 edges and they are all touching each other end to end Blend will have some difficulty in automatically sorting them.
