Hi stefano,
> I then tried to select the same face - as the dialogue. top right also gives its diameter and height...
> So is there a way to resize the hole in a single click with V5.
I'm planning on putting it in the "Edit size" menu that pops up when you click on that Diameter/height line but it isn't hooked up quite yet.
It needs a bit of an overhaul so it can work with multiple selection.
