Connect two faces
11968.8 In reply to 11968.7
> What is the "Multi Blend Edges" ?
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
> A script or just the normal way to use the Blend function ?
It's built in to the regular Blend command.
