Natural Curve Extension and Other Questions
11952.2 In reply to 11952.1
Hi OSTexo,
> Does the ACIS kernel support natural curve extension?
Can you post an example? There is a NURBS extension method usually referred to as something like "polynomial extension".
That name "Natural" is probably a term made up by a particular app.
> Is it possible to have Make2D output an overall outline as well as visible and
> invisible lines as different styles?
It doesn't try to make an outline for Make2D currently because there isn't a way to keep a separate stroke width or clipping by a shaded background image when exporting those curves later on.
What I mean is that when generating a hidden line drawing by export to PDF, AI, or SVG formats the outline is meant to look like this:
It's clipped in half by being below the shaded background image and has a larger width than regular visible curves.
