Is there a script that will replace a shape with another shape?
11945.7 In reply to 11945.5
Or to simplify cleanup you can draw in a rectangle for the cell size like this, then you can delete all the old shapes, move the new shape onto the lower left corner of that cell and use the lower left to upper right corners for the array spacing. Then you'll only have that one spacer rectangle to remove for cleanup.
