Merge UV Maps
11941.2 In reply to 11941.1
Hi Yanus3D, usually UV mapping would be done in a poly modeling program. MOI does provide a simple automatic mapping where each surface maps to the entire 0,0 to 1,1 unit square.
Depending on what poly modeling software you are importing into there is often a function "separate islands" that will separate those out so they don't refer to the same area.
