Temporary Lock of Geometry via Keystroke & Moving Geometry?
11939.4 In reply to 11939.3
Hi OSTexo,
Attached is a script called HideMem that I use in place of the native Hide. It keeps a memory of what was hidden last and if it's run again with nothing selected it will un-hide the most recently hidden stuff. The isolate part of it also works a little differently to allow drilling into nested groups.
I like your idea of storing the full history of hide operations so that they can be undone sequentially. This script could be modified to do that, though I don't have time to tackle that at the moment. One problem with this script is that it runs slowly in heavy scenes; especially those with a lot of nested groups.
Install by going to MoI's appdata folder.
On Windows you can find the MoI appdata folder by typing Win+R to bring up the Windows "Run" dialog and then type in:
%AppData%\Moi\
On Mac from a Finder window, go to the menu and pick Go > "Go to folder" and type in:
~/Library/Application Support/Moi/
You should see the folders “commands”, "startup", and "scripts". Put HideMem.htm and HideMem.js in scripts.
To set up shortcut keys go to Options > Shortcut Keys and paste in each of following three lines as a separate key:
HideMem
script:/* view hidden objects */moi.command.setOption('HideMem', 'ctrl'); moi.command.execCommand('HideMem');
script:/* isolate */moi.command.setOption('HideMem', 'rmb'); moi.command.execCommand('HideMem');
To replace the native Hide button with this version put EditTabContent_customizer.js in the startup folder.
- Peer
