Temporary Lock of Geometry via Keystroke & Moving Geometry?
11939.3
Hello Michael,
Yes, I'd like to be able to select a surface and toggle lock it via keyboard shortcut. That'll allow me to stay in the work field rather than bouncing back and forth between work field and command selection. I wonder if it's possible to have lock history with that as well, may be helpful when dealing with levels of detail.
Sounds good, I'll continue the point helper trick when moving faces.
Is there a way to have hide and unhide history via keyboard shortcut similar conceptually to lock and unlock? For example if I have three objects and I hide them in order 1,2,3 is it possible to unhide them via keystroke 3,2,1?
That would be helpful as I'm making my way down different branches of a model to modify or defeature rather than searching for objects in the tree.
Thanks.
