Hey Nick,
I have a bit of input for you...
Here is a quick mockup from your image. I left the construction curves so you can see
See if this gets close to what you had in mind.
(If its not something you can follow, I should be able to recreate it pretty quick for you)
I didnt use any real world dimensions. Just winged a visual then resized the final solid to be closer to an actual size. If I was doing a real item, I would use very specific dimensions.
Regarding the "scan data" I would only use this as a reference to rebuild the item in NURBS, which is best for your CNC process. Most CAM packages will prefer NURBS data to work with. Some stuff will work with poly's, but you will be limited. This depends on your CAM package and machining process...
If you need organic stuff added to the stock, like deforming things or adding image "Emboss" type work, this will be done with other software. For us, our CAM package has the "Embossing" built into it. There are other "specialty software made for that (Think Vetric). Either way, it is a process "AFTER" you have modeled the part in CAD.
Think of the CAD part of the process as creating the precise piece and dims. (Your lower receiver cutouts, etc) Then using something else to "Paint" it. (The "paint" being modeling you cant/shouldnt do in CAD)
