Linux mint
11918.2 In reply to 11918.1
Hi Raven, when running on Wine Moi will use a directory .moi inside your user dir for appdata.
for example moi.ini will go in ~/.moi/moi.ini and you'll have ~/.moi/commands for appdata commands, etc...
Also you should be able to see where the moi.ini file is located by using Options > General > "Edit .ini file" button. That will bring up a dialog that shows the path to the moi.ini that is currently being used.
