Add "Make corner point" as a shortcut key?
11915.2 In reply to 11915.1
Press CTRL when you click a point ! You win a shortCut!
For avoid to recall the fonction Curve , enable repeat case...
For close the function press Right Click, Right Click again for recall the function if repeat is not enabled!
EDITED: 29 Jan by PILOU
