Rolling a rack to create a gear profile
11914.3 In reply to 11914.1
Hi Fubax,
>Now I have an issue, because I want to create a non-circular involute gear,
> and I need to "roll-array" the rack over a curve (arch) with parallel offset to the
> curve to avoid slip at each step. I believe it would be possible with MoI, the
> script would essentially be the "Curve Array" with a roll offset option.
I'm sorry but I'm not understanding what you are trying to do.
How is your ArrayRoll different than circular array?
Do you want the object to rotate in some way on every array step?
Kinda need some more details.
