smoother lofting?
11888.5 In reply to 11888.4
Hi Rusty,
To get that result, use the 5 section file.
I rebuilt the curves to clean them up a bit. Default setting
When you run loft, you will see a bunch of points in a line. These are the lofts seam edge. while in loft, drag each of those seam points down to the tip of the trailing edge of each section.
This will help loft with a uniform span.
