Splitting model in squares?
11882.7 In reply to 11882.1
Hi Matadem,
> and I want to split the model into squares
To split a model into square chunks, draw one square of your target size:
Select it and run Transform > Array > Grid. It will ask you for the number of copies to make, the default is to make 10 in x and 10 in y.
For the spacing pick the first point here:
And second point here:
You will now have a grid of squares, position your object within it and select your object:
Run Construct > Boolean > Intersect, then select the squares and you'll get split up pieces like this:
Hope this helps! - Michael
