Hemispherical dome design ?
11879.2 In reply to 11879.1
Hi Sven,
> I'm unable to find the points where lines intersect sphere surface.
Are these the lines here? :
If so, select the lines and the sphere:
And run Construct > Curve > Isect . That command will generate curves at intersections between surfaces or points at intersections between curves and surfaces:
