Hi Martin,
> Michael. How does Move work in those options?
Oh by the way there are shortcuts - Right click on the name will do "Assign selection here" without opening the menu, Ctrl+Left click will do rename and Shift+Left click will do Move.
Those 3 functions Rename, Move, Delete work directly on that scene browser item's objects without regard to selection.
So for example here renaming or deleting all unnamed objects without needing to set selection first as was previously needed:
So "Move" will wait for you to pick another item and then it's like drag and drop except better because you don't need to keep the mouse button down and try to control auto scroll behavior while dragging in a long list. You can just use mouse wheel, regular scroll bar and expand/collapse while you go to the target.
Move is primarily for putting things into or out of group hierarchies, currently moving a name tag onto another name tag doesn't do anything since those don't have parent/child hierarchies. Oh yeah in Styles you can use it to order the style list.
But on groups it's like this:
