Unexpected chamfer transition result Beta 5 Sept 17.
11858.4 In reply to 11858.1
Hi GuyLuke, it looks like you want a variable width chamfer with the chamfer width dropping to 0 some distance further along the edge?
Unfortunately MOI does not have a variable width chamfer option. It does have a variable radius fillet however.
The way you could use it is to cut this edge using the Edit > Trim command with the "Add trim points" button so that it will be split like this:
Then select the edges and run Fillet, put in 0.5 for the main radius and then under "Fillet set" add in a new point set, set the "Linear Blend option", pick the point where you split the edge and enter in 0 for the radius there.
That will build a fillet like this, then you can delete the fillet surfaces and use Loft between 2 edges at a time to build the chamfers.
= Michael
