Hi AG101, the default for pan is already by holding down the middle mouse button, either with shift or just by itself with no modifier key.
If your 3D view is rotating with the middle button and panning with the right button you probably have the option turned on under Options > View > "Rotate/Pan/Zoom options" > "Rotate with middle button".
Turn that off to return back to the default behavior:
