Hi Matadem, you can find the cmorph plugin here:
http://moi3d.com/wiki/MaxScriptArchive
or for your curves case you may want to use Construct > Loft to build a solid between the shapes and then you can extract section lines from a solid or surface either by arraying a line and using Construct > Curve > Project or by arraying planes and using Construct > Curve > Intersect.
Here using Transform > Array > Dir on a line and then Construct > Curve > Project:
