Mobius Ribbon - Paper Style
11832.2 In reply to 11832.1
Hi Alex, what is your process for the flattening?
Also I'm a little confused about the whole process, with the flow method for example you are starting with a flat shape then it's twisted and use curve to curve flow to make the 3D shape?
If you want to add text, won't you add that to your starting flat shape? Why is there an ending flattening being done?
