...bring object into c-level - how?
11817.4 In reply to 11817.3
Hi Mala, I'm not quite understanding the 3 lines in your model, are those meant to be the x,y,z axis lines for a coordinate system on the circle?
The part that is confusing is that usually something like that should have each axis at a 90 degree angle to the other axes. But yours is not set up like that.
There is a command Transform > Orient that can move and rotate objects from one coordinate system to another.
Here is an example using Transform > Orient on your circle to reposition it:
