What can cause svg import problems?
11811.5 In reply to 11811.1
Hi Matadem, you can get this to work in MOI by first opening the .svg in Inkscape.
Then inside Inkscape choose File > "Clean Up Document" and then File > Save As to a new filename, and MOI will be able to read that new file.
It looks like MOI’s .svg importer can get confused when there are unused <def> elements in the svg file. The “Clean up document” command in Inkscape removes the unused <def>s.
