Fast mirror from center line?
11810.2 In reply to 11810.1
Hi Matadem,
> so Let say I draw a cirlce at the left side of the X press a button (shortcut) it copies to the other side?
I've attached a plugin that can do that.
This command will perform a mirror as if you had drawn a mirror line in the Top view along either the X or Y axis lines.
It takes a parameter value of either "x" or "y", so set up your keyboard shortcut like this:
MirrorXY x
or
MirrorXY y
Instructions for installing a plugin here.
