offset / loft problem
1181.9 In reply to 1181.8
Hi Lemo,
> However, I can't get the results.
You mean on the same curves that you posted before, or on a different set of curves?
On the curves that you posted before, I needed to do the steps to split up the original curve so that it matched the offset segments.
If you're talking about a different set of curves, please post them as well and I can give you some more recommendations and steps on how to process them. But it will likely be the same steps I showed above about using Trim to split up the original curve into matching segments.
> After an offset, I end up with a curve which contains MANY more segments.
There isn't really any way around this - when your offset creates sharp corners you will get segments between each sharp corner piece. So you need to split up the original curve into equivalent segments.
