Forgotten nodes in Elephant
When i draw my own points seems each point draw a line to the other points!
I want of course only a line!
I must make something special first ?
When i load the previous file that works normaly... apparently... when you select them... but
i suspect the same process : each point connects all the other ones on the same line! ;)
It's for that my lines was "fat lines" on my previous image! :)
So I suppose than the node must be modified!
A vicious glitch is hiden somewhere! :)
EDITED: 25 Sep 2025 by PILOU
