Looking for timing pulley script?
11804.1
Any one know of a MOI3D script for generating timing pulleys using standard timing belt parameters for common timing belts, eg, GT2, HTD, etc.?
I occasionally have a need to 3D print a timing pulley but my efforts to recreate the GT2 profile using MOI3D has been average at best. Using MOI3D, I've managed to design a reasonably accurate belt profile but I'm painfully learning that the mating pulley profile needs 'tweaked' a bit for a quality fit.
I've also located a couple of OpenSCAD programs that generate STL files for parametric timing pulley designs, but I've yet to find a simple method to convert the STL files to STEP. So making changes / customizing the OpenSCAD exports is problematic. Seems I recall that Fusion360 can import STL files and export STEP files with some effort? I tried the same conversion using FreeCAD but the conversions never worked.
Thanks for any suggestions.
Scott
