You can also setup the surface you want to be "pillowed" like upholstery by using a grid pattern and then adjust your control points. This is how it is done with sub-d modeling approach.
make your curves, loft the curves to make a surface, show points on surface and adjust depth in the pattern.
You can adjust the depth and tightness or falloff by moving the neighboring control points further or closer as shown on the far right example
