Create solid from copied elements
11789.5 In reply to 11789.4
Hi Pascal,
> Is there a way to keep a tool live while typing the values?
It depends on the tool but often times things try to finish up when a value is typed in to reduce the number of operations needed to run it.
For curve offset if you are in "Through Point" mode it will finish when you pick the point. If you are in "By distance" mode you can adjust the distance, it won't finish until you pick a point for which side you want.
