Moi3d surface modeling question
As you see Add points on deformed surface is not easy
You can use Cmorph by Max Smirnov + LineWeb by Michael .... for a more regulated result! ;)
In your case you must Flip one of the Half perimeter curve before use the Lineweb
else curves will be crossed!
(select curve(s) Press Tab and write "Flip" )
