How to make a 2D curve follow the shape of a 3D object (like a box) in MoI3D?
11778.6 In reply to 11778.4
Hi KhoeHuynh,
> But is there any way I can cut just the top part?
If you select the top face as the projection target then it will only make a projection there.
You can select face or edge subobjects on a solid by a second click on it. The first click will select the whole solid, and then when the whole solid is selected a second click on it will "drill in" to select faces or edges.
So in your case where you want to project a line onto the top face, select the line:
Then run Construct > Curve > Project.
The prompt in the upper right corner of the window will say "Select projection target".
Select the top face by 2 clicks on the box, the first click will select the whole box and the second click on it will drill in to select just faces or edges:
Then click "Done" or right click in a viewport (shortcut for "Done") and you'll be at the last step in the project command where you can adjust the projection direction. Click "Done" or right click in a viewport again to finish the Project command with this result:
Note that if you want to actually cut the whole box into 2 separate solid chunks you can use boolean difference to do that without needing a separate projection step and if you want to cut just the top face into 2 separate faces you can use Edit > Trim to do that without needing a separate projection step either.
