So to create the "Sharp Serrations" on the tooth, a machinist wouldn't "Model the little jaggeds" on the model. We used Array Path to put a specifically spaced (Determined by size of V-Bit. Think of a cone shaped tool with tip on the little lines) amount of profile paths for the machine to use to move into the edge of the part... This will create the "Serrated edge"....
The experiment will be to determine if a second set of "In between spaced" lines will be needed to be profiled from the 180, to look best. It will be easy enough to create and take just a bit more time to test up....
