Best way to create dome?
11775.3 In reply to 11775.1
Hi Matadem, here attached is the set up for your shape using rail revolve.
First select the profile curve:
Run Construct > Revolve > Rail revolve.
The prompt will say "Select rail curve". Select the top ellipse edge:
The next prompts will say "Pick revolve axis start point" and then "Pick revolve axis end point". Pick these 2 points on the center axis line:
A solid dome with the bottom capped will be created and you can boolean union this onto the base extrusion.
